Use the following options to display Layer 3 VSN with IP Multicast over Fabric Connect information to confirm proper configuration.
show ip vrf mvpn
show isis spbm ip-multicast-route [all][detail]
show isis spbm ip-multicast-route [group {A.B.C.D}][detail][source {A.B.C.D}]
show isis spbm ip-multicast-route [vrf WORD<1–16>] [group {A.B.C.D}]
show isis spbm ip-multicast-route [vlan <1-4059>][detail][group {A.B.C.D}]
show isis spbm ip-multicast-route [vsn-isid <1–16777215>][detail][group {A.B.C.D}]
show isis spb-mcast-summary [count][host-name WORD<0–255>][lspid <xxxx.xxxx.xxxx.xx-xx>]
Display Layer 3 VSN with IP Multicast over Fabric Connect information:
Switch:1>enable Switch:1#show ip vrf mvpn Vrf name : green mvpn : enable fwd-cache-timeout(seconds) : 210 Vrf name : 4 mvpn : enable fwd-cache-timeout(seconds) : 210 Vrf name : blue mvpn : enable fwd-cache-timeout(seconds) : 210 Switch:1#show isis spbm ip-multicast-route all ================================================================================ SPBM IP-multicast ROUTE INFO ALL ================================================================================ Type VrfName Vlan Source Group VSN-ISID Data ISID BVLAN Source-BEB Id -------------------------------------------------------------------------------- routed GRT 501 192.0.2.1 233.252.0.1 5010 16300001 10 el2 routed GRT 501 192.0.2.1 233.252.0.2 5010 16300002 20 el2 routed GRT 501 192.0.2.1 233.252.0.3 5010 16300003 10 el2 routed GRT 501 192.0.2.1 233.252.0.4 5010 16300004 20 el2 routed GRT 501 192.0.2.1 233.252.0.5 5010 16300005 10 el2 routed GRT 501 192.0.2.1 233.252.0.6 5010 16300006 20 el2 routed GRT 501 192.0.2.1 233.252.0.7 5010 16300007 10 el2 routed GRT 501 192.0.2.1 233.252.0.8 5010 16300008 20 el2 routed GRT 501 192.0.2.1 233.252.0.9 5010 16300009 10 el2 routed GRT 501 192.0.2.1 233.252.0.10 5010 16300010 20 el2 -------------------------------------------------------------------------------- Total Number of SPBM IP multicast ROUTE Entries: 10 -------------------------------------------------------------------------------- Switch:1#show isis spbm ip-multicast-route vrf green =========================================================================== SPBM IP-MULTICAST ROUTE INFO =========================================================================== Source Group Data ISID BVLAN Source-BEB --------------------------------------------------------------------------- 192.0.2.10 233.252.0.1 16300001 10 el2 192.0.2.10 233.252.0.2 16300002 20 el2 192.0.2.10 233.252.0.3 16300003 10 el2 192.0.2.10 233.252.0.4 16300004 20 el2 192.0.2.10 233.252.0.5 16300005 10 el2 192.0.2.10 233.252.0.6 16300006 20 el2 192.0.2.10 233.252.0.7 16300007 10 el2 192.0.2.10 233.252.0.8 16300008 20 el2 192.0.2.10 233.252.0.9 16300009 10 el2 192.0.2.10 233.252.0.10 16300010 20 el2 -------------------------------------------------------------------------- Total Number of SPBM IP MULTICAST ROUTE Entries: 10 -------------------------------------------------------------------------- Switch:1#show isis spbm ip-multicast-route vlan 501 ========================================================================== SPBM IP-multicast ROUTE INFO ALL ========================================================================== Type VrfName Vlan Source Group VSN-ISID Data ISID BVLAN Source-BEB Id -------------------------------------------------------------------------- routed GRT 501 192.0.2.1 233.252.0.1 5010 16300001 10 el2 routed GRT 501 192.0.2.1 233.252.0.2 5010 16300002 20 el2 routed GRT 501 192.0.2.1 233.252.0.3 5010 16300003 10 el2 routed GRT 501 192.0.2.1 233.252.0.4 5010 16300004 20 el2 routed GRT 501 192.0.2.1 233.252.0.5 5010 16300005 10 el2 routed GRT 501 192.0.2.1 233.252.0.6 5010 16300006 20 el2 routed GRT 501 192.0.2.1 233.252.0.7 5010 16300007 10 el2 routed GRT 501 192.0.2.1 233.252.0.8 5010 16300008 20 el2 routed GRT 501 192.0.2.1 233.252.0.9 5010 16300009 10 el2 routed GRT 501 192.0.2.1 233.252.0.10 5010 16300010 20 el2 ------------------------------------------------------------------------- Total Number of SPBM IP multicast ROUTE Entries: 10 ------------------------------------------------------------------------- Switch:1# show isis spbm ip-multicast-route vsn-isid 5010 ========================================================================== SPBM IP-multicast ROUTE INFO - VLAN ID : 501, VSN-ISID : 5010 ========================================================================== Source Group Data ISID BVLAN Source-BEB -------------------------------------------------------------------------- 192.0.2.1 233.252.0.2 16300002 20 el2 192.0.2.1 233.252.0.3 16300003 10 el2 192.0.2.1 233.252.0.4 16300004 20 el2 192.0.2.1 233.252.0.5 16300005 10 el2 192.0.2.1 233.252.0.6 16300006 20 el2 192.0.2.1 233.252.0.7 16300007 10 el2 192.0.2.1 233.252.0.8 16300008 20 el2 192.0.2.1 233.252.0.9 16300009 10 el2 192.0.2.1 233.252.0.10 16300010 20 el2 ------------------------------------------------------------------------- Total Number of SPBM IP multicast ROUTE Entries: 10 -------------------------------------------------------------------------- Switch:1# show isis spb-mcast-summary ========================================================================== SPB multicast - Summary ========================================================================== SCOPE SOURCE GROUP DATA LSP HOST I-SID ADDRESS ADDRESS I-SID BVID FRAG NAME -------------------------------------------------------------------------- 5010 192.0.2.1 233.252.0.1 16300001 10 0x0 el2 5010 192.0.2.1 233.252.0.3 16300003 10 0x0 el2 5010 192.0.2.1 233.252.0.5 16300005 10 0x0 el2 5010 192.0.2.1 233.252.0.7 16300007 10 0x0 el2 5010 192.0.2.1 233.252.0.9 16300009 10 0x0 el2 5010 192.0.2.1 233.252.0.2 16300002 20 0x0 el2 5010 192.0.2.1 233.252.0.4 16300004 20 0x0 el2 5010 192.0.2.1 233.252.0.6 16300006 20 0x0 el2 5010 192.0.2.1 233.252.0.8 16300008 20 0x0 el2 5010 192.0.2.1 233.252.0.10 16300010 20 0x0 el2
